btwixt
May 23, 2022Guide
RN102 unresponsive after initiating FW update from 6.10.6 to 6.10.7
Initiating update from local admin page, everything seemed normal including the blinking power light during the update process. I received a status email that the unit was rebooting, and I watched...
May 23, 2022Guru - Experienced User
Did you try powering down, and powering up again?
btwixt
May 23, 2022Guide
Unit is unresponsive to power button. Shall I pull the power plug?
- btwixtMay 23, 2022Guide
Pulled the power plug & waited a few minutes.
Applied power and unit appeared to start without touching power button.
The amount of time from applying power to power LED going from blinking to solid on was
only about 6 seconds, much faster than a normal boot. And, unit is unresponsive
to any access and power button. I have not tried the reset button.
