btwixt
May 23, 2022Guide
RN102 unresponsive after initiating FW update from 6.10.6 to 6.10.7
Initiating update from local admin page, everything seemed normal including the blinking power light during the update process. I received a status email that the unit was rebooting, and I watched...
btwixt
May 23, 2022Guide
Unit is unresponsive to power button. Shall I pull the power plug?
btwixt
May 23, 2022Guide
Pulled the power plug & waited a few minutes.
Applied power and unit appeared to start without touching power button.
The amount of time from applying power to power LED going from blinking to solid on was
only about 6 seconds, much faster than a normal boot. And, unit is unresponsive
to any access and power button. I have not tried the reset button.
- SandsharkMay 23, 2022Sensei
Does RAIDar find the unit? What status does it show?
- btwixtMay 23, 2022GuideRAIDar finds nothing.
My router LEDs show that it is physically connected at 1Gbps but router admin page does not list it as an attached device.- SandsharkMay 23, 2022Sensei
How about with the drives removed? Do the removal with power off, then power on and see if RAIDar reports "No disks". It's best if you mark them as you remove them so you can put them back in the same order (also, with power off).
