matex
Sep 17, 2014Aspirant
RN10200 - DLNA, USB, backup
Hi, I’m new on the forum. Soon I’ll buy a RN10200 but I’ve three question before: - RN10200 with two HD WD Red can stream a 1080p video via DLNA? - can I access to the files on the USB or eSATA har...
Sep 17, 2014Guru - Experienced User
Yes. Even full BluRay streaming requires only 54 mbits, and the ReadyNAS can deliver ~560 mbits on a gigabit network. But if is not capable of transcoding the audio or video to a different format. If you need that capability, you'll need a 300 or 500 series ReadyNAS.
matex wrote: RN10200 with two HD WD Red can stream a 1080p video via DLNA?
Yes. Though it is not as fast as internal disks. You're better off getting a 4 bay unit.
matex wrote: can I access to the files on the USB or eSATA hard disk from my PC?
No. You need multiple backup jobs. You can back up the entire volume with one job, but if you want a subset of shares you need one backup job for each.
matex wrote: I tested ReadyNAS Live Demo "Sandbox" ... it seems that I can select only a folder to backup each job, so if I want to backup multiple folders I have to define multiple jobs. Is there a way to select multiple folders?
