Benpar's avatar
Benpar
RN10200 not connecting to sagemcom f@st 5366
I am having an issue with my RN10200 with a new modem router, Sagemcom F@st 5366 supplied with my new service. The NAS will not communicate with router. No communication lights flash when plugged in, i have tried all ports and multiple cables.
  • StephenB's avatar
    Are you sure the ethernet ports in the sagemcom work?  (are you able to test them with another device?).
    • Benpar's avatar
      Benpar
      Yes, i have a security camera system that is working and i have confirmed it works in every port
      • StephenB's avatar
        Ok.
        Have you tried both ethernet ports on the NAS?
        It might be worth seeing if RAIDar can find the NAS. https://kb.netgear.com/20684/ReadyNAS-Downloads Sometimes the NAS is connected properly to ethernet, but isn't getting a DHCP address.
        Do you have a switch you can put in between the NAS and the router?  If the router has "green ethernet" features, then it is conceivable that is interfering with the ethernet autonegotiation.
ProSupport for Business
