admartin
Jul 08, 2015Aspirant
RN10200 Unrecognised disks
My RN10200 has suddenly stopped recognising the disks it has in it. I couldn't access the drives a couple of days ago, its IP address is recognised and can be pinged successfully from the router. I ...
Jul 08, 2015Guru - Experienced User
I would contact support. Maybe also test the disks with seatools.
If the disks are healthy and the NAS doesn't see them, then I'd suspect hardware. In that case you are covered under warranty, not limited by the 90 software support.
