ecybertom
Feb 06, 2017Aspirant
RN104 - "Remove inactive volumes to use the disk." problem #27199519
I was 'running out of room' with 2X6TB disks and 2X5 TB disks, installed 5-6-5-6. I replaced the slot 1 disk with an 8GB disk, giving an 8-6-5-6 arrangement. Resync et al went well. I then added a...
ecybertom
FramerV
Feb 10, 2017NETGEAR Employee Retired
Hi ecybertom,
Do you have any updates about this case? Might be best to also do a back-up of your files (if possible).
Contacting support would be best as far as I can tell so that they can further check what went wrong.
