RatPC
Dec 06, 2019Aspirant
RN104 - Unable to view Shares in GUI - RNOS 6.10.2
Evening All, A bit of a strange one going on here, and i cant quite work out what is going on. Logging in to the WebGUI and looking at the shares page it only shows me the home folders as sho...
JohnCM_S
Dec 06, 2019NETGEAR Employee Retired
Hi RatPC,
Welcome to the Community!
If you are comfortable in using SSH on your NAS, you can try running the script provided here.
That should fix the issue that you are currently experiencing on your NAS.
- RatPCDec 06, 2019AspirantThat’s worked perfectly!
I will reset the Permissions in the morning :)
