davidereitano
Aug 29, 2017Aspirant
RN104 error, freeze, don't shutdown and sync at reboot
Hello. One of my RN104s is litterally making me crazy. From about a month it is continuously doing this: -Freeze -Error on display (do_exit+9ac) -I can't shut down the system and i must remov...
JennC
Aug 30, 2017NETGEAR Employee Retired
Hello davidereitano,
If you can still get to the files stored to the volume, back up the file.
What's the size of the MTU that is set on the NAS?
JennC
Aug 31, 2017NETGEAR Employee Retired
It may be best to contact support, then. I think this is somethign they can check from the backend.
- Jan 17, 2024Retired_Member
