BrainzUK
Mar 06, 2026Aspirant
RN104: ghost “NG-8TB-Seagate” volume (RAID unknown) Inactive/Unprotected
I have a ReadyNAS RN104 that’s working fine from the data point of view, but the volume configuration seems corrupted and is generating constant volume health alerts that I cannot clear. I’m hopi...
Mar 06, 2026Guru - Experienced User
BrainzUK wrote:NG-WDRED-3TB-1 (0 data, 0 free, RAID unknown)
This was the old 3 TB drive (which was primary).
[26/03/05 20:45:16 GMT] notice:volume:LOGMSG_HEALTH_VOLUME Volume NG-8TB-Seagate health changed from Unprotected to Inactive.
[26/03/05 20:45:20 GMT] info:volume:LOGMSG_DELETE_VOLUME Volume NG-WDRED-3TB-1 was deleted from the system.
[26/03/05 20:45:29 GMT] notice:volume:LOGMSG_HEALTH_VOLUME Volume NG-8TB-Seagate health changed from Inactive to Unprotected.
[26/03/05 20:45:32 GMT] notice:volume:LOGMSG_HEALTH_VOLUME Volume NG-8TB-Seagate health changed from Unprotected to Inactive.
[26/03/05 20:45:34 GMT] info:volume:LOGMSG_DELETE_VOLUME_NEW_HOME_FOLDER Home folders are newly created on volume NG-8TB-Seagate.
[26/03/05 20:45:47 GMT] notice:volume:LOGMSG_HEALTH_VOLUME Volume NG-8TB-Seagate health changed from Unprotected to Inactive.
This was deleted after the new Seagate was installed - I can't tell if you did that manually or if the system did it on its own.
As I mentioned in the PM, several logs are flooded with the 8 TB volume health toggling between inactive and unprotected. I can't see the underlying errors that are causing that.
If the 3 TB drive you replaced was healthy, then I'd suggest switching back to that temporarily. But it's not - over 20 thousand ATA errors, and 76 pending sectors.
I think the path forward is to replace the Seagate with an Ironwolf (though unfortunately you might be past the return window). But I think testing the drive first would be useful.
