XAffi
Aug 11, 2016Aspirant
RN104: Sata <-> USB 3.0 converter compatibility
Hi. Has anyone information about compatibility of SATA <-> USB 3.0 converter (e.g. ICYBOX HDD docking stations) attached to RN104? Thanks Norbert
- Aug 16, 2016
Hello XAffi,
Yes, according to one of the higher tier of support team it should work.
JennC
Aug 12, 2016NETGEAR Employee Retired
Hello XAffi,
I'm checking this with others. By the way, have you already tried this or not yet?
- StephenBAug 12, 2016Guru - Experienced User
One poster here said ICYBOX converters worked through 6.4.x, but then failed in 6.5.x. Netgear Support was able to fix it. There's no way to tell from the thread if this was a general issue or a one-of problem.
