XAffi
Aug 11, 2016Aspirant
RN104: Sata <-> USB 3.0 converter compatibility
Hi. Has anyone information about compatibility of SATA <-> USB 3.0 converter (e.g. ICYBOX HDD docking stations) attached to RN104? Thanks Norbert
- Aug 16, 2016
Hello XAffi,
Yes, according to one of the higher tier of support team it should work.
XAffi
Aug 12, 2016Aspirant
Hi StephenB,
Thanks for the Info. Seems I was not able to find the Info you are refering to... Getting support in general is good enough. Thanks. Norbert
