XAffi
Aug 11, 2016Aspirant
RN104: Sata <-> USB 3.0 converter compatibility
Hi. Has anyone information about compatibility of SATA <-> USB 3.0 converter (e.g. ICYBOX HDD docking stations) attached to RN104? Thanks Norbert
- Aug 16, 2016
Hello XAffi,
Yes, according to one of the higher tier of support team it should work.
Davexyz2
Aug 15, 2016Aspirant
I use Icy Box Raid expansion units
What happened is that in 6.4 (and in all firmwares) the drive is mounted via a start up script when the Readynas starts up. What happeneed in 6.5 was that the external drive needed more time to be recocognised, due to the size of the drive, >6Tb in general, so moving a line of code to the end of the start up script was required. This is now I believe the deafault situation in 6.5.1 and "higher"
