booboo59
May 11, 2019Apprentice
RN104 turns on unattended
I'm a pretty competent Linux user but this is baffling me. My RN104 turns itself on one a month around the 10th of each month (if the NAS is turned off). What is triggering this? I cannot find a s...
Retired_Member
May 11, 2019Hi booboo59, to get more info about a potential power issue I would do the following:
Case1: If the nas is currently hooked up to a ups, around the evening of the 9th of a month I would disconnect it from the ups and directly hook it up to a power outlet in the wall. Then see what happens on the 10th.
Case2: If the nas is currently NOT hooked up to a ups, try one. There are cheap models from APC, which are very reliable. I'm using several Back-UPS ES 700 and have virtually no power issues at all.
Good luck with fixing and kind regards
