tiff_lee
Jul 16, 2019Tutor
RN104 unable to login or reinstall OS. Have updated firmware (6.10.1) using USB recovery
Ok so currently my NAS is working in the sense I can access it as my network drive, however I am unable to login to the administrator page as my admin password for some reason no longer works. I cer...
Marc_V
Jul 16, 2019NETGEAR Employee Retired
How are you accessing the NAS? By IP or thru ReadyCloud? Have you checked if a different browser will let you log in on the Admin page? Clearing cache would be useful too. OS Reinstall should have reset the password do default which is "password".
If you don't have any data on the NAS then a Factory reset might be fit to perform but doing USB Recovery should have helped as well.
Please let me know if clearing the cache and using a different browser worked and if it still has the same issue kindly send me link to download your NAS logs.
HTH
Regards
tiff_lee
Jul 16, 2019Tutor
Hi Marc,
I am accessing via its IP (mapped as a network drive) but I can also access it via readycloud.
Cleared browser cache and just tried with a different browser (firefox) same issue. I input admin/password and then it just prompts me to submit login details again.
Not sure about what you mean regarding a link to download my logs, I must be missing something here because even I can't download them? RAIDar is prompting me for login details to download the logs and with no access to the admin page that's ruled out as well.
- Marc_VJul 16, 2019NETGEAR Employee Retired
Thank you for the message, getting the free space of the data or OS volume lower than 20% causes NAS performance degradation and this can possibly be the cause why you are experiencing the issue. As you have mentioned you can transfer the files to an external HDD to free up space and also perform volume maintenance on the NAS if you get access on the NAS after freeing up space.
Please see https://kb.netgear.com/26638/ReadyNAS-OS-6-How-to-Enable-and-Configure-Volume-Maintenance on configuring and scheduling maintenance tasks.
HTH
Regards
