Doug6392
Jul 14, 2020Guide
RN10400 - multiple failed disks or failed NAS hardware?
Using latest firmware and 4 WD Red 4TB HDDs in RAID5 configuration. NAS fell on its side (vacuuming accident) and overnight registered 2 failed disks and a dead drive. Am currently doing HD diagnosti...
- Jul 16, 2020
Doug6392 wrote:
StephenB wrote:
Doug6392 wrote:
Tried rebooting with a known good HDD, and it rebooted into a legacy boot mode.Was this drive formatted? If it was, then the NAS might be fine.
Try the fast write-zero test in lifeguard - that will remove the partitions. Then put it back in the NAS and power it up, and see if you get a different result.
Impressive, StephenB ! I did as you suggested, and instead of booting into Legacy Mode, the NAS appears to be booting normally. I will go ahead and run the other tests as suggested (keeping my fingers crossed!) and post the result.
Thanks very much.
Final (hopefully!) update: after running through the tests suggest by Sandshark it appears that all drive bays are functioning properly. I added another old but still serviceable HDD (on which I first performed the quick erase as suggested by StephenB ), and on bootup the NAS is working to expand the existing JBOD. I can now go ahead with some confidence to begin to replace the failed HDDs. Thankfully, the last time I had a NAS hardware failure (2015, when I upgraded to my current NAS) I also learned the hard way that a NAS isn't a backup, so I have a complete backup of all the data lost in my sad vacuuming accident. :)
Many thanks again for your prompt and capable assistance.
Jul 14, 2020Guru - Experienced User
Doug6392 wrote:
Using latest firmware and 4 WD Red 4TB HDDs in RAID5 configuration. NAS fell on its side (vacuuming accident) and overnight registered 2 failed disks and a dead drive. Am currently doing HD diagnostic on disks reported failed. Did factory default and one of 2 remaining disks reported failed. NAS is well out of warranty; before I invest in new HDDs, does this sound like the disks or the NAS failed? Thanks.
Sounds like the disks to me, but there could also be damage to the NAS.
You could test the disks in a Windows PC with WD's Lifeguard software. You can connect them either with SATA or a USB adapter/dock.
Doug6392
Jul 14, 2020Guide
Thanks. That's what I'm using to test the drives (in a dock), although it's painfully slow. I'm also running a memory test on the NAS at the same time; it should be finished first: I understand that if it doesn't finish in about 4 hours, then I may have my answer. (Hopefully they're not both borked! ;) )
- SandsharkJul 14, 2020Sensei
Unfortunatly, the SATA backplane is also at risk, depending on what side of the NAS hit the ground. Here is your best test:
Using a known good drive (one of the old ones you've tested, or any you might have around), install just that drive and create a JBOD volume on it. (This will, of course, erase any data on the drive, but I think you realize your volume is alreay toast.) Then test it by adding a few files and accessing them. Or use a speed test program. Then power down, swap drive to the next bay, power up, and test again (you won't have to re-create the volume). Repeat for bays 3 and 4. Check the log for any signs of a problem (esp. mentions of ATA errors), and check the drive SMART, too.
It's not a comprehensive test, but any backplane damage isn't likely to propagate, so it's pretty good at finding anything.
- Doug6392Jul 14, 2020Guide
Sandshark wrote:Unfortunatly, the SATA backplane is also at risk, depending on what side of the NAS hit the ground. Here is your best test:
Thanks for what sounds like a great suggestion. Might be a day or 2 before I can try it but I will post the result as an update.
