PowerFang's avatar
PowerFang
RN10400 - NETGEAR Storage Failed! Message on front of NAS
Heyas,   I've woken up this morning to my NAS making noise on its fan (normally its pretty silent but now i can hear the fan), and on the front of the NAS, it says "NETGEAR Storage Failed!".   ...
  • StephenB's avatar
    Oct 29, 2018
    Try running RAIDar, and see what information it reports. https://kb.netgear.com/20684/ReadyNAS-Downloads#raidar
    PowerFang wrote:
    The configuration i had running in the NAS was one HDD that basically backed up the photos and 2 other HDD were in Raid 0?  Basically they were in the RAID mode were they are mirrors of each other so if one fails, i can just replace the HDD and it will re-mirror between them.
    I think you are remembering that incorrectly.  If you are using the default XRAID, then with 3 disks you'd be using RAID-5.  That doesn't use mirroring, though it can rebuild any of the drives from the other two.
    More fundamentally, RAID is not enough to keep your data safe.  It's useful (in particular it keeps your files available during routine disk replacements).  But it can fail (as can the NAS itself).  The only way I know of to keep data safe is to keep at least one copy on another device.  Personally I keep three independent copies of everything I care about.
    PowerFang wrote:
    Any help super appreciated.  My initial thoughts is to remove the HDD and plug it directly into my computer to get the files off it -
    That won't work - Windows and Mac PCs don't support the BTRFS file system used on the NAS.  There is a software package called ReclaiMe that does data recovery.  You'd need to attach at least two of your disks to the PC to use it.  They can be attached over USB.
    Netgear also offers a data recovery service: https://kb.netgear.com/69/ReadyNAS-Data-Recovery-Diagnostics-Scope-of-Service
    Check the warranty status of your NAS - if you are the original purchaser, the hardware warranty is 3 years.  If you still are covered by the warranty, then you could start the RMA process to get a replacement NAS via my.netgear.com.
ProSupport for Business
