partialpoet's avatar
partialpoet
RN10400 Error do_exit+8dc on reboot
I have a new ReadyNAS RN10400 after setting it up with a new drive and updating to the firmware to the latest I shutdown to move the box to is permanent home and now on booting it get the power light flashing and the screen shows the message do_exit+8dc. I have tried to reinstall the OS, which works, but again on reboot the same error message.  Has anyone else had a similar problem or no what is causing this?
  • mdgm-ntgr's avatar
    mdgm-ntgr
    NETGEAR Employee Retired
    Which firmware was the latest when you updated the firmware?
    Which firmware did you update from?
    • partialpoet's avatar
      partialpoet
      i don't remember the orginal firmware, but it is now on 6.5.0
ProSupport for Business
