mah_2019
Apr 28, 2019Aspirant
RN10400 ReadyCloud Backup and Sync App - ReadyNAS Offline
Hi -
New to this community. Sorry if this has been posted earlier, but was unable to solve my issue. I have an older version of RN10400 4bay Netgear NAS with two 2T drives installed. Trying to ...
mah_2019
Apr 29, 2019Aspirant
Thanks for you response. I am able to get to the NAS drive admin page using brower, but I would like to use the BackUp Sync App from ReadyCloud to backup my PC. When i go to this app, it says drive is offline.
I am not sure how to enable ReadyCloud on the NAS.
thanks
Apr 30, 2019Guru - Experienced User
Start by logging into the web admin UI and going to the cloud page.
If ReadyCloud isn't enabled, then enable it there. You should see two green checkmarks on that page (one indicating internet connectivity, the other indicating that the NAS is connecting to the ReadyCloud service).
Personally I'm with Sandshark on this. I don't recommend that particular method of PC backup, especially if you are mostly on the same network as the NAS. It doesn't back up everything on the PC, and there isn't any good way to schedule it, etc.
So I think there are better backup solutions (including some free ones).
