Anonymous
Jan 15, 2016[RN202-100NES] Spin-down not working - wake up after seconds
Hello Guys :) I am new on ReadyNas devices, but have the following problem: The Hard Drives itself spins down, but after some seconds its spins up again. Didnt matter which time I choose for spi...
- Jan 19, 2016
Can you try turning off IPv6 temporarily to see if the device remains in spindown mode?
Anonymous
Jan 15, 2016The logfile is on the way...
I hope you mean the Services which I can setup on ReadyNAS OS webinterface ?
The following Service are running: SMB, HTTP, HTTPS, SSH
mdgm-ntgr
Jan 15, 2016NETGEAR Employee Retired
Yes, those. As you mentioned uninstalling all your apps, I would conclude there are no apps running.
- AnonymousJan 15, 2016
Yes, at this moment no Apps are installed right now.
- AnonymousJan 16, 2016
I got some new point: I have one AVM FritzBox 7390 Router / Gateway behind an easy 8-port network switch from tp-link
I played around with Wireshark today and found out that the HDD drives spins up pn every ICMPv6 echo (Router Advertisment).
Tested it 5 times with Wireshark and its always on ICMPv6 - Router Advertisment).
Btw. I have already sent the log files...
- AnonymousJan 19, 2016
Nobody an idea ?
Problem still available :(
