doug714
Nov 30, 2020Aspirant
Rn202 Keeps going offline for 3 minutes
My RN202 keeps going offline for exactly 3 minutes. Running 6.10.3 Today it has done this 4 times. Ideas anyone?
- Marc_VNETGEAR Employee Retired
Welcome to the Community!
It would be best if you can download the logs and check on status.logs or kernel.logs
I suspect a OOM (out of memory) issue. Are you running any apps?
If you are not comfortable reading the logs kindly send the full logs to me via PM.
HTH
- doug714Aspirant
Marc_V wrote:Welcome to the Community!
HTH
I have downloaded my logs and will send them to you via PM as I really don't know how to read them. The only app that is running is Plex Media server. Thanks for your help! Doug
- Mar 26, 2017Retired_Member
