SalmonMan
May 03, 2020Tutor
RN20200 access remotely not showing all files
I can access files on my home network but when I access from remote location, the folder tree is truncated. Not all the folders show up.
SalmonMan
May 07, 2020Tutor
I tried to downlaod the App on my Mac but it won't let me. It says it can't runit because Apple can't check for malicious software. Stuck.
May 07, 2020Guru - Experienced User
- SalmonManMay 08, 2020Tutor
I tried again on a different Laptop PC. When I use the WEB App my directory is truncated like on the MAC. I downloaded the ReadyCloud App and using it I could see all of the directory on the PC Laptop. Later I tried to launch the App and it would not start up. So I can't run the App on the MAC which is my main use for outside the LAN and the WebAPP doesn't work correctly to show all of my directory. Any advice out there?
