zyphaz
Apr 15, 2016Aspirant
RN204 6TB hot-add expansion resync: ~90 DAYS?
I added a 4th 6TB HDD to what was intially a 3x6TB setup in my RN204. I expected the rebuild to run into the weekend with a hot-add of that size... but checking the estimated resync time ~19 hours l...
mdgm-ntgr
Apr 15, 2016NETGEAR Employee Retired
Which firmware are you running?
Which services are you running?
Which apps are you running?
Welcome to the Community!
zyphaz
Thanks for the welcome.
6.4.2
System > Settings > Services is empty.
Apps > Installeld Apps is empty.
- StephenBApr 15, 2016Guru - Experienced User
Surely you jest. Did you click on it to expand it? It should something look like this:
If the antivirus service is enabled, then disable it.
- zyphazApr 15, 2016Aspirant
Could it be a symptom of a larger issue that I'm experiencing?
I'm remote from the NAS so I don't have physical access to it at home. But I can VPN and open a support case if that's where this is going.
Perhaps clear your browser cache, and look one more time.
Something is very wrong if there are no services showing - so you should open a support case if you still see that.
