zyphaz
Apr 15, 2016Aspirant
RN204 6TB hot-add expansion resync: ~90 DAYS?
I added a 4th 6TB HDD to what was intially a 3x6TB setup in my RN204. I expected the rebuild to run into the weekend with a hot-add of that size... but checking the estimated resync time ~19 hours l...
zyphaz
Thanks for the welcome.
6.4.2
System > Settings > Services is empty.
Apps > Installeld Apps is empty.
Apr 15, 2016Guru - Experienced User
Surely you jest. Did you click on it to expand it? It should something look like this:
If the antivirus service is enabled, then disable it.
- zyphazApr 15, 2016Aspirant
Could it be a symptom of a larger issue that I'm experiencing?
I'm remote from the NAS so I don't have physical access to it at home. But I can VPN and open a support case if that's where this is going.
- StephenBApr 15, 2016Guru - Experienced User
Perhaps clear your browser cache, and look one more time.
Something is very wrong if there are no services showing - so you should open a support case if you still see that.
I cleared cache and still had the same results viewing Services, I rebooted the RN204 and now I see a list of services. AV is disabled.
The amount of time remaining has dropped to ~90 hours, which is more in line with what I'd expect for a 4x6TB rebalance.
"Have you tried turning it off and on again?"
