cydeweyz
Aug 18, 2021Tutor
RN204 Fan has Failed
I received this email alert today from my Readynas- "Fan System in enclosure Internal speed is below threshold. (0 rpm)." I checked my nas and found the fan not moving. The nas kept operating, but I ...
Aug 19, 2021Guru - Experienced User
cydeweyz wrote:
Does anyone know where I can find a replacement fan for this unit?
You should be able to get the fan specs from the model number on the fan, and then purchase a compatible replacement.
I know its a 92 mm case fan, but I haven't seen any specs here.
