jcontech
Jul 20, 2021Aspirant
RN212 v6.10.5 Hot Fix 1- Antivirus Scanner Failed to Update
Antivirus scanner definition file update failed due to download failure. Check your Internet connection. The last update was 10/28/2020 I've read previous threads of users uploading the latest f...
Jul 22, 2021Guru - Experienced User
HansRL wrote:
@ StephenB, My guess is the reported error (ReadyNASOS service or process was restarted) has everything to do with the failing "antivirus scanner definition file update" and probably caused by consuming all the memory by the virus update process. I got the same errors when I encounter this issue.
Quite possible, though I'd add a full OS partition might also be a cause.
HansRL
Jul 30, 2021Apprentice
@ jcontech,
in another post I described a solution or by-pass which worked for me, so probably you did not see that post, so I re-post it here now:
1) enable SSH on your NAS (can be done via the gui: system-tab and option setting)
2) on your PC install WINSCP
3) FILE-PROTOCOL: SCP ; HOST NAME: IP-address of your NAS ; PORT NUMBER: 22 ; USER NAME: ROOT ;
(your ROOT-password is the same as your ADMIN-password) ; click LOGIN
4) similar to EXPLORER go to directory: /var/lib/clamav/
5) right-click the members (antivir;bytecode;daily;main;mirrors) and choose DOWNLOAD AND DELETE
put/save them somewhere on your PC
6) change or go to directory: /etc/clamav/
7) right-click on member freshclam.conf and choose EDIT
8) click after "ReceiveTimeout 120" and hit ENTER
copy/past "TestDatabases false"
member should look like below:
DatabaseOwner root
LogSyslog true
LogFacility LOG_LOCAL6
Debug false
MaxAttempts 5
DatabaseDirectory /var/lib/clamav
DNSDatabaseInfo current.cvd.clamav.net
ConnectTimeout 120
ReceiveTimeout 120
TestDatabases false
ScriptedUpdates true
CompressLocalDatabase false
Bytecode true
NotifyClamd /etc/clamav/clamd.conf
OnErrorExecute /usr/bin/clamav_event -s 1
OnUpdateExecute /usr/bin/clamav_event -s 0
Checks 2
DatabaseMirror database.clamav.net
DatabaseMirror db.cn.clamav.net
DatabaseMirror db.tw.clamav.net
9) close window in which your are editing freshclam.conf (save it of course)
10) restart your NAS
Hopes this will solve your issue
- AdriFrijtersNov 01, 2021Tutor
Hello all,
Again i have the same problem. Is there a 'how to fix it' for dummies?
- StephenBNov 01, 2021Guru - Experienced User
AdriFrijters wrote:
Hello all,
Best option is to try 6.10.6 beta. https://community.netgear.com/t5/ReadyNAS-Beta/ReadyNASOS-6-10-6-Beta/m-p/2151119#M10972
The version of ClamAV in 6.10.5 is being deprecated by the ClamAV folks.
- AdriFrijtersNov 05, 2021Tutor
Stephen,
thanks but as a 'Dummie' it's more wise to wait a few days for the final.
