tommy747
Jan 05, 2019Aspirant
RN214 compatibility with WD80FAX?
Hello,
I'm wondering if anyone has used the Western Digital WD80FAX 8TB drives in their units. From what I see on the WD site, this drive is very similar to the WD80FZX, but is not listed on ...
Jan 05, 2019Guru - Experienced User
I use the WD80EFRZ (though it's presently in an RN524 I did use it in an RN202 for a while).
Tne WD80EFAX looks like it should be fine, though I think it doesn't have the side center mounting holes. If that's correct you will have to remove the tooless plastic inserts from the trays, and screw the disks in with the screws provided when you purchased the NAS. Likely only one pair of mount holes will align (which is ok).
tommy747
Thanks so much for your information. The new unit will arrive tomorrow and I will see how these WD drives hold up.
- john_jsbbsMar 24, 2019Aspiranttommy747
Any chance of a progress update with the WD80EFAX drives?- tommy747Mar 24, 2019Aspirant
Update on the WD80FAX drives, they have work flawlessly so far. My RN214 has been running for several months and no drive errors of any kind. I'm thinking of adding the 4th drive to fully populate the RN214.
