sgatymsi
Mar 07, 2019Aspirant
RN214 FAILED reboot after update to 6.9.5
RN214 was working for several months with firmware 6.9.4.
After update to 6.9.5 shows FAIL on front panel, power button flashing, not seen by DHCP router. Does not recover when power cycled, or wh...
Mar 08, 2019Guru - Experienced User
I suggest contacting paid support, perhaps requesting an RMA.
sgatymsi
Mar 08, 2019Aspirant
Oh well, I thought perhaps this was an easily fixed problem. Thanks for your suggestion.
- StephenBMar 08, 2019Guru - Experienced User
Try powering down and removing all the disks (labeling them so you can put them back in the proper spots).
Then power up, and see if you see a "no disks" status on the LCD. RAIDar should also report that. https://kb.netgear.com/20684/ReadyNAS-Downloads
