GJSchaller
Jan 13, 2020Guide
RN214 on 6.10.2: The volume data encountered an error and was made read-only.
This past weekend, my ReadyNAS gave the following error: The volume data encountered an error and was made read-only. It is recommended to backup your data. There's no indication what the actual...
- Jan 13, 2020
Those BTRFS errors might be able to fixed on the backend but it would be best if you start over. Cause of this errors might be due to dirty reboots that caused transactions to not complete. Not really sure how to explain but if you have any chances of outages or power loss or disk failures while in use then that can contribute.
HTH
Regards
Marc_V
Jan 13, 2020NETGEAR Employee Retired
Have you checked status.log or volume.log for any warnings or information on Root OS volume or Data volume has been consumed to 100%? You may also want to check dmesg.log for any kernel or btrfs errors.
If there are FS errors, I would suggest doing a Factory reset if possible.
HTH
Regards
Jan 13, 2020Guru - Experienced User
In addition to dmesg, you can look directly in system.log and kernel.log for disk and btrfs errors. Maybe also look at disk health (disk_info.log).
If you want to see OS partition fullness, scroll down to the end of volume.log at the df section. The OS partition is /dev/md0.
FWIW, several folks here have found that when they rebooted with a read-only volume that the volume didn't mount. That hasn't happened to you yet, but I wouldn't count on that continuing.
