GJSchaller
Jan 13, 2020Guide
RN214 on 6.10.2: The volume data encountered an error and was made read-only.
This past weekend, my ReadyNAS gave the following error: The volume data encountered an error and was made read-only. It is recommended to backup your data. There's no indication what the actual...
- Jan 13, 2020
Those BTRFS errors might be able to fixed on the backend but it would be best if you start over. Cause of this errors might be due to dirty reboots that caused transactions to not complete. Not really sure how to explain but if you have any chances of outages or power loss or disk failures while in use then that can contribute.
HTH
Regards
GJSchaller
Jan 13, 2020Guide
OK, now we're getting somewhere.... found this in dmesg.log:
[Sun Jan 12 17:18:29 2020] BTRFS error (device md127): parent transid verify failed on 7765871394816 wanted 4157903 found 4225465 [Sun Jan 12 17:18:29 2020] BTRFS error (device md127): parent transid verify failed on 7765871394816 wanted 4157903 found 4225465 [Sun Jan 12 17:18:29 2020] BTRFS warning (device md127): Skipping commit of aborted transaction. [Sun Jan 12 17:18:29 2020] BTRFS: error (device md127) in cleanup_transaction:1864: errno=-5 IO failure [Sun Jan 12 17:18:29 2020] BTRFS info (device md127): forced readonly [Sun Jan 12 17:18:29 2020] BTRFS: error (device md127) in btrfs_drop_snapshot:9412: errno=-5 IO failure [Sun Jan 12 17:18:29 2020] BTRFS error (device md127): could not do orphan cleanup -30 [Sun Jan 12 17:18:29 2020] BTRFS info (device md127): delayed_refs has NO entry
Marc_V
Jan 13, 2020NETGEAR Employee Retired
HTH
Regards
