rodneyat2
Mar 11, 2020Aspirant
RN214 Performance issues
I have actually had this issue for a while. But, just getting around to dealing with it in depth. Performance on my RN214 has been marginal since I purchased it. My configuration is as follows: 4 ...
Mar 11, 2020Guru - Experienced User
rodneyat2 wrote:
So my NAS is currently directly connected to the router (Netgear Orbi RBR50). The macbook I am doing the testing with is connecting directly to the router wirelessly. My wireless speeds on the macbook directly to the internet are 400+ mb/s.
How are you measuring the wireless speed?
I don't have a Mac, but looking at screenshots of Blackmagic it appears to be reporting MB/s (megabytes), not mb/s (megabits). FWIW, 34 MB/s translates to 272 mb/s.
What is your ISP speed (just wanting to sort out if the 400 mbps is limited by the mac-orbi link, or if it is limited by the ISP WAN connection)?
Have you tried a different speed test (for instance, copying a large video to/from the NAS, and just timing it?
rodneyat2 wrote:
4 Western Digital Green WD20EZ 2TB disks.
Not disks I would recommend (FWIW, WD doesn't recommend them for RAID either). I generally suggest NAS-purposed drives for an RN200 series. Still, these might not be the issue.
Have you downloaded the full log zip file? If so, look in disk_info.log to check the disk health, and look in network_settings.log for ethernet issues. It'd be best to download the log zip before and after the transfer test, so you can sort out the errors that occured during the test itself.
- rodneyat2Mar 11, 2020Aspirant
You are obsolutely correct. I did not see that Blackmagic had "MB" not mb. Gotta pay closer attention to the "B". :). So, that said, the performance is not to bad afterall. On your question about ISP speed..I have 400 mb/s Internet. So, I am getting right at what I am supposed to get getting when I am hitting the internet. So, I will do some more testing and see what I come up with. Thx for the input.
- StephenBMar 11, 2020Guru - Experienced User
Then it's possible that your local wifi is faster than the 400 mb/s.
The RN214 is capable of delivering > 100 MB/sec for large file transfers. I'm not sure exactly what Blackmagic is doing, but there are some loads that are always much slower - for instance directory browsing.
If you are comfortable using ssh, then it is possible to install some stuff that would let you measure the network throughput w/o doing file transfers. It would also be possible to check the raw read/write speeds of your array (with no network).
But looking in the logs would be a good next step. A failing disk would definitely hurt the speed, and of course is something you'd want to replace.
- rodneyat2Mar 12, 2020Aspirant
Thx..I did some further testing. And the peformance seems to be farily consistent with multiple computers and even at multiple locations in my house. The wireless performace is not an issue. Inside my network, i can get speeds in the 900mb/s range, computer to computer. So, the network is doing what it should be doing. I looked at the logs after a transfer and there were no glaring issues there. The ethernet port is at 1000 full duplex, no errors on the port. A very small number of dropped packets but that is normal with ethernet. No errors on the disks. So, I am guessing it is really a straight up disk performance issue. I just have to decide if it's worth upgrading the disks. Or living with it as is.
