berillio
Jun 10, 2025Aspirant
RN214, query on a 2nd vertical expansion
Hello Forum Simply query, just checking. Can I carry out a “vertical expansion” more than once? I have a RN214 ( 6.10.3, X-RAID) which already went from 4x 4TB to 4x8TB, and I am just about t...
berillio
I did not say but the RAID is near full, 21.00TB shown on the pie in Volumes (with 0 snapshots). For Info, the SCRUB I just run took almost 32 hours. Is that roughly the time which will be needed for any resinch operation? I just thought of another way of doing this which maybe quicker,
- a) buy the other 2x 12 TB ( 2days, say, to receive them)(actually I just ordered them);
- b) fit my existing 12TB on a PC which I have, which has 6 SATA slots;
- c) copy/move all the 20TB on these 2x 12TB. Than may need 21,000,000 / 80 (MB/sec) = 262500 seconds = 73hours, ~4days (I can start doing this while waiting for the new hdds to be delivered);
- d) ReadWriteVerify test the hdd(s) once thy arrive (~15h each);
- e) remove the 8TB drives frome the RN214, fit 2 of them to the PC, and copy over the contents of one of the 12TB which is now free;
- f) fit the NAS with 3x 12TB hdd and copy the data (another 4 days). After that, the data is availlable in a RAID in a protected state;
- g) wipe the 12TB left on the PC and fit it to the NAS (that would be an horizontal expansion). That will do ONE SINGLE resinch and should have a simple RAID 5 on the 4 hdd ( not a RAID+ RAID 1+ RAID 2 raid structure
Wouldn’t that be faster and simpler than doing the 3rd vertical expansion as I described earlier?
Sandshark
Jun 10, 2025Sensei
Hopefully, you've not unboxed the 12TB drives, because your plan is very inefficient cost wise. Updating all 4 8TB to 12TB only adds 12TB of storage at the price of 4 x 12TB drives. For less money (and fewer re-syncs), you can swap out two for 24TB drives and get a 16TB increase with the option of later swapping another, and then later another, for yet another 24TB for an additional 16TB from each. I believe 24TB to be the best size-to-cost ratio available today. On Amazon, a 24TB Ironwolf Pro is the same price as a 20TB.
The only reasons to be doing what you are is if you suspect all the 8TB drives are in need of replacement or if you are using FlexRAID (which requires all drives be of equal size). But if you are using FlexRAID, the incremental syncs StephenB listed are not what you will see.
- StephenBJun 10, 2025Guru - Experienced User
I agree that would be more cost-effective to get fewer larger drives.
Though I believe berillio is in the UK, not the US. Looking at amazon.co.uk, the most cost effective combination I see is 3x16TB+8TB. That adds 16 TB at ~£49/TB gained (£784 total cost).
My suggestion above would give him a much smaller storage gain, but would also give him enough capacity in the PC to back up his volume going forward. That could be modified to go with 2x16TB+2x8TB, with a 16TB and one or two 8 TB drives in the PC for backup. Cost would be the same (assuming no exchange fee on the disks), and it would give him more space in the volume than my original suggestion.
FWIW, I am seeing 20 TB at about $400, and 24 TB at about $480. Cost per TB is the same (perhaps that is what you meant)?
- SandsharkJun 11, 2025Sensei
When I looked, both were $399US. Amazon prices can change quickly and I now see that as well. But moot since the OP is in the UK.
But looking at the cost per TB, including cost for future expansion, is still a good idea.
- berillioJun 11, 2025Aspirant
Hello Stephen B, TY for your support, Hello Sandshark, Ty for the suggestion.
Too late for that, this afternoon I received the last 2x 12TB drives ( I could return them if I wanted, even if unpacked, see further down). They were £237 each, the only 20TB NAS drive I can see on the same “shop” is the IronWolf Pro @£360, but no 24TB (no WD 24TB but a 22TB Red Pro@£511, and a 18 Red Pro @£365. I searched another shop and they were even more expensive, so, as StephenB hinted, price on this part of the pond may be very different. TBH I am NOT that comfortable with the larger size which Sandshark is suggesting, but that may simply be because I am not used to them.
I didn’t say in the previous posts that the 8GBs which will come out (which are in perfectly good condtion, no errors reported, 19990,19970,19841 and 14845 hours of use), will be fitted to the Zimablade #2 which is in transit. I also have Zimablade #1 which is fitted with 2x 4TBs which came out of other RNs in the past, 2 or 3 more 4TB have been filled with data and are in “cold storage”, I can easily plug them in the Zimablade and read the data off them.
I should eventually end up with 16TB on the Zima plus extra 12TB in the expanded 214.
The initial plan was to get another Zimablade (#2), so I bought 2x 8TB (IronWolf DB002 running @5400rpm); on arrival one tested fine, but the other wasn’t even read by the BIOS, so I filed the return as DoA (Dead On Arrival), but then even before they replied to me, I thought of expanding the NAS contacted the shop and returned both of them.
- Sep 06, 2016Retired_Member
