berillio
Jun 10, 2025Aspirant
RN214, query on a 2nd vertical expansion
Hello Forum Simply query, just checking. Can I carry out a “vertical expansion” more than once? I have a RN214 ( 6.10.3, X-RAID) which already went from 4x 4TB to 4x8TB, and I am just about t...
Sandshark
Jun 16, 2025Sensei
Start with XRAID. You can still choose RAID0 as the initial volume, then it will automatically do exactly what you are planning for the expansion. The OS sometimes disallows your ability to switch from FlexRAID to XRAID. Nothing you plan should trigger that, AFAIK, but there is no need to take the chance.
There is no need to reset anything. In fact, you shouldn't. All configuration is stored on the drives, so a reset would do nothing if done without the drives and wipe the drives (making putting them back in useless if you find you forgot something) if done with them.
berillio
Jun 17, 2025Aspirant
GRRRRR
I have been refreshing the page every 30 mins since I posted it, but I never saw any reply until few minutes ago (the following day) when I refreshed “the entire tree”. Last night (say 20h ago), I started copying back the files and it has done ~4tb by now. I suppose I could “delete the volume” and reboot. The disks are now formatted and it shouldn’t go into “safe mode” which is what happened yesterday, and meant restarting EVERYTHING passwords, emails, fixed network node etc..
Then I could start again keeping the X-RAID, at moment it doesn’t allow me to switch “Cannot select X-RAID on RAID 0 or RAID 10” because I don’t have the redundant disk
Sandshark, the Soft Manual says that X-RAID doesn’t support RAID 0, but infact when I started, X-RAID was there (as default), even after I selected RAID 0 (albeit it wasn’t highlighted in green), and it was me who switched it o Flexi-RAID. So…. I should have left it on and maybe it would have gone green when I added the 3 rd disk.
StephenB, I will follow advice and go 6.10.9… now ( I stopped the data copying already)
- SandsharkJun 18, 2025Sensei
If you still have all the drives from the original volume and you want things to be set up the same as they were, you could put those drives back in and save the configuration, then restore it on your new volume. The volume name must be the same to do that. If you had apps installed, you should re-install them before restoring, so if you had apps you don't plan to re-install, don't backup "everything", just do the users & groups and share access. If you have ReadyCloud users you are removing, then this is probably not a good idea.
I believe you are correct that it would have gone green when you added the third drive. At the Linux level, a RAID0 created by the OS is actually a RAID that's missing a member (so no redundancy), but it's flagged that the OS won't complain abo0ut that missing element. A single drive RAID1 is a RAID1 with a missing member and a 2-drive or more is a RAID-5 missing one, So it's not showing green because there is no redundancy (I missed that in my experiments).
- berillioJun 18, 2025Aspirant
Hi SandShark & StephenB,
I took up both tips, DESTROYed the Volume, updated to 6.10.9 ( I don’t really use apps but who knows, tomorrow I may wish to do so ), recreated the Volume but this time I left it on X-RAID (“not green”). Happily copying the data, 5.38TB done, which is ~half of the first disk, so ~3days more, then I should be able to hot-add the 3 disk, then the 1st resinch, on a 36TB volume, after which the X-RAID should turn green. After that the same again with the 4th disk, 2nd resinch of a 48TB volume, so it may take a little longer. I am not sure if I could hot-add both the 3rd and 4th disk together, but OS6 may still do two resinches anyway. I am not in a rush, so why risk to confuse things..?
- StephenBJun 18, 2025Guru - Experienced User
The NAS can't do two syncs in parallel.
Do one hot-add at a time. That makes it easier to troubleshoot if something were to go wrong.
- Sep 06, 2016Retired_Member
