strykeroz's avatar
May 28, 2019
RN214 ReadyNAS Alert Message (ReadyNAS Volume:Critical) email
Hi guys I've been trying to register my ReadyNAS 214 (RN21400, purchased January) for a support ticket unsuccessfully for some nights now, and in the interim the problem has worsened and it no lon...
  • StephenB's avatar
    May 28, 2019
    strykeroz wrote:
    I'm happy to have a go with telnet. So booting into tech support mode enables this?
    First you should choose whether you want Netgear support to fix it, or if you want to try and fix it yourself.  It can be messy to go down both paths at once.
    If you do want to use tech support mode, then instructions for booting are on pages 58-59 here: http://www.downloads.netgear.com/files/GDC/READYNAS-100/ReadyNAS_%20OS6_Desktop_HM_EN.pdf
    You should disconnect your USB drives before booting up in tech support mode.
    The login is root, and the password is infr8ntdebug.
    Once in, you need to start raid and chroot by entering
    # rnutil chroot
    The data volume won't be mounted (which actually makes troubleshooting the space usage easier, since there are a couple of mount points on the OS partition that can hide what's underneath).
    One thing to look at is the USB mount points in /media.  If there is an issue with mounting, then sometimes the backup jobs will write directly to the folders (for instance /media/USB_HDD_1 ).  Those folders should be empty - if they aren't, you should delete whatever's in them.  Similarly /apps should be completely empty.
ProSupport for Business
