strykeroz
May 28, 2019Tutor
RN214 ReadyNAS Alert Message (ReadyNAS Volume:Critical) email
Hi guys I've been trying to register my ReadyNAS 214 (RN21400, purchased January) for a support ticket unsuccessfully for some nights now, and in the interim the problem has worsened and it no lon...
- May 28, 2019
strykeroz wrote:
I'm happy to have a go with telnet. So booting into tech support mode enables this?
First you should choose whether you want Netgear support to fix it, or if you want to try and fix it yourself. It can be messy to go down both paths at once.
If you do want to use tech support mode, then instructions for booting are on pages 58-59 here: http://www.downloads.netgear.com/files/GDC/READYNAS-100/ReadyNAS_%20OS6_Desktop_HM_EN.pdf
You should disconnect your USB drives before booting up in tech support mode.
The login is root, and the password is infr8ntdebug.
Once in, you need to start raid and chroot by entering
# rnutil chroot
The data volume won't be mounted (which actually makes troubleshooting the space usage easier, since there are a couple of mount points on the OS partition that can hide what's underneath).
One thing to look at is the USB mount points in /media. If there is an issue with mounting, then sometimes the backup jobs will write directly to the folders (for instance /media/USB_HDD_1 ). Those folders should be empty - if they aren't, you should delete whatever's in them. Similarly /apps should be completely empty.
May 28, 2019Guru - Experienced User
strykeroz wrote:
so I can find/delete the large files and disable ClamAV (which seems to get the blame for this often)?
From what I've seen here, the recent ClamAV issue only happened on RN100 systems - not the RN200 or above. If you use plex, I suspect it is more likely to be the cause.
strykeroz wrote:
Is there a way to boot to USB and mount the RAID
Not exactly. What you'd do is boot the system in tech support mode. Then you can connect with telnet (if you know how), and mount the OS partition.
If you have some knowledge of linux, and want to pursue this path let us know, and we can provide more information.
strykeroz
May 28, 2019Tutor
Thanks guys.
FWIW I've not been using plex. I do have the wasabi cloud service running, and two rsync jobs daily copying to an attached USB drive, and dropbox connected as well.
It's late so rather than risk making things worse I'll have a crack tomorrow night.
Cheers!
Geoff
- StephenBMay 28, 2019Guru - Experienced User
# rnutil chroot
- strykerozMay 29, 2019Tutor
StephenB wrote:One thing to look at is the USB mount points in /media. If there is an issue with mounting, then sometimes the backup jobs will write directly to the folders (for instance /media/USB_HDD_1 ). Those folders should be empty - if they aren't, you should delete whatever's in them. Similarly /apps should be completely empty.
Thanks Stephen you called it. /apps was empty but /media/USB_HDD_1 included the remains of a failed backup and this had choked the filesystem. I leave that 5TB USB drive connected and powered - not sure under what circumstance it would have become unmounted. Is there a mechanism for preventing this issue recurring?
- StephenBMay 30, 2019Guru - Experienced User
strykeroz wrote:
Is there a mechanism for preventing this issue recurring?Not that I know of.
Clearly it's a bug (the NAS failed to detect that the disk was no longer mounted). Fortunately it doesn't happen often.
BTW, you can troubleshoot this w/o tech support mode if you have ssh enabled. The trick is to remount the OS partition as /mnt
# mount --bind // /mnt
Then look in /mnt for the files. There will be no mount points on those placeholder folders, so you can see what's in them. The lack of mount points also speeds up the search.
When done, use umount to dismount it.
# cd // # umount /mnt
If you do damage with ssh (or tech support mode for that matter), Netgear reserves the right to deny paid support until you do a factory default.
strykeroz wrote:
Thanks Stephen you called it.I'm glad I could help :smileyhappy:
