tviner1964
Oct 27, 2022Aspirant
RN214 Shows Failed! Message on boot
I've just purchased an RN21400 and have populated with 4x 3TB WD RED HDD's. The unit will power up and shows all 4 drive LEDs. However, the only message displayed after Booting... is Failed! with t...
- Oct 28, 2022
tviner1964 wrote:
However, I think the drive was pulled from the unit before it had fully booted resulting in the failed condition.
USB recovery just puts the firmware install image back into the flash memory. I don't think pulling a drive during installation would have any effect on the flash, so I think there is a bit of a mystery on what happened.
But the good news is that the recovery was successful.
Oct 27, 2022Guru - Experienced User
WD30EFRX? OR WD30EFAX?
FWIW, the WD30EFAX are SMR drives, and several folks here have had trouble with SMR disks in an OS-6 ReadyNAS.
tviner1964 wrote:
Is there a hardware reboot/factory default function without going through the rest/power button routine that will force the system to return to factory settings?
Of course the factory default option in the boot menu does that.
The other way is to zero or unformat the disks in a PC. If the NAS sees unformatted disks, it automatically does a fresh factory install.
Note the NAS boots from the drives, and all the settings are on the drives.
Overall, I suggest testing the NAS with just one drive. If you have a spare (other than the WD Reds), you could also try that, which would rule out a disk problem.
Once you get the NAS installed on one drive, power it down and move the disk to the next slot. Then power up, and make sure it boots. Repeat this until you've gotten the NAS to boot up from each bay.
