kmmcd
Jun 07, 2017Aspirant
RN214 vs RN314 Questions
Greetings. I have an old (in computer years) ReadyNas Duo and am looking to upgrade to something with greater storage capacity. At present, I am considering the RN214 and RN314. To that end, I ha...
- Jun 09, 2017
kmmcd wrote:
e) is it better to just plug the two new WD Red 6TB drives into the RN424, format them, create shares, etc., and then copy the old data from the Duo across the network to the new RN424 drives?
Yes. That also allows you to use the Duo for backup.
Note that once the data is migrated, you can do a factory reset on the duo - changing it to flexraid, and creating two RAID-0 volumes (one for each disk). That gives you 4 TB of backup (though it isn't protected from drive failure). I've done this with my own duo.
Using two volumes in the Duo does require you to manual balance storage (choosing which shares to place on which volume). But a single RAID-0 volume will completely fail if either disk fails. I've found balancing the storage isn't that difficult, and it's a lot more robust.
mdgm-ntgr
Jun 07, 2017NETGEAR Employee Retired
1) The new model is the RN424. The RN420 series has 2-bay, 4-bay, 6-bay and 8-bay models, namely the RN422, RN424, RN426 and RN428 respectively.
2) Those two are good choices. Not all disks are compatible and some disks are more suited to different use cases than others. We do have a compatibility list
3) Using the default X-RAID with two disks it would use RAID-1 then change to RAID-5 when you add a 3rd disk.
4) Over time higher capacity disks have been released. Resellers tend not to update their pages with new datasheets. There are 10TB disks on the compatibility list so it should support a 40TB volume. Though that's before redundancy. Using RAID-5 with 4x10TB disks you'd get a volume capacity of about 27TiB.
5) ReadyCLOUD is optional. You don't have to use it. Some users use their NAS units on networks not connected to the internet. You can install the RAIDar discovery client on your Mac/PC but that's optional too. Your router should show the NAS in attached devices so you can find the I.P. by finding which I.P. has been assigned to the MAC address of a NIC in your NAS.
6) To use some modes such as LACP the switch/router your NAS is directly plugged into needs to support it and be configured to use it.
7) No.
8) Starting off with two 8TB disks should be fine.
If your data is important to you and the NAS will be holding the primary copy of it you should factor into your budget how you'll backup your important data whether to the Duo or to another NAS or to a USB disk or some place else.
aks
Jul 03, 2017Virtuoso
mgdm, does this mean the RN214 series are moving to EOL?
- StephenBJul 03, 2017Guru - Experienced User
aks wrote:
...does this mean the RN214 series are moving to EOL?
The RN21x??? Where did you get that idea?
I suspect the RN31x is being phased out in favor of the RN42x. But I haven't heard anything from Netgear on that.
- TeknoJnkyJul 03, 2017Hero
netgear has so many different model numbers, which are segmented into various consumer/prosumer/business variations, its impossible to keep track of what goes EOL and when.
Of course this isn't a netgear specific problem, but one with nearly every manufacturer of technology goods.
- aksJul 04, 2017Virtuoso
StephenB wrote:
aks wrote:...does this mean the RN214 series are moving to EOL?
For this reason:
kmmcd wrote:
At present, I am considering the RN214 and RN314. To that end, I have some questions, the answers for which I would be extremely grateful:
mdgm replied:1) The new model is the RN424. The RN420 series has 2-bay, 4-bay, 6-bay and 8-bay models, namely the RN422, RN424, RN426 and RN428 respectively.
I agree it could mean the RN42x replaces the RN31x, but I note the RN20x is now gone off sale, and, I still am the proud owner of the EOL'd soon after I purchased NV+ v2!
I do need to upgrade, I keep telling myself it will be fine, but I find reasons not to do it. Actually, I don't have a big reason to upgrade, the NV+ v2 works fine. Yes it's a bit slower than current models, yes it has the v5 software, but in the main it just works (for home use). My biggest concern is security patches which seem to have stopped. So, I don't want to buy a RN214 to find it is also EOL'd with short notice (again), that would simply be too annoying.
The RN42x are too expensive for my use case, the RN21x is just about ok when discounted, which means around £250 in UK. Currently they are back up to £300, so I'll be patient and wait again.
- bedlam1Jul 04, 2017ProdigyPresumably it would only be the chassis which went EOL, OS 6 would still be supported as it is the current firmware for all current models
