ecybertom
Dec 28, 2018Aspirant
RN21400 HAVING VOLUMN ERROR AND GOING READ ONLY
I have two of this model, one purchased in 11-16-16 and one 9-5-18. Both running Firmware 6.9.4. Both were turned off for 2 months and restarted 12-4-18. Within a few hours of restarting, both (and a...
Dec 28, 2018Guru - Experienced User
Are you seeing any disk or btrfs errors in the logs? Perhaps search system.log and kernel.log.
- ecybertomDec 29, 2018Aspirant
Yes, btrfs errors. See attached
- StephenBDec 29, 2018Guru - Experienced User
Well, that explains it.
Make a backup if you can - if not, you'll need data recovery to extract the data from the volume.
I'd start by testing the disks in a windows PC (seatools for seagate, lifeguard for western digital).
- ecybertomJan 14, 2019Aspirant
The Btrfs's are associated with a device identified as md126. Is there some way to trace which drive that identifies or is that the whole system. I've been preoccupied with other efforts so am just getting back to identify the drive(s).
