EmilyRogers22
May 11, 2019Aspirant
RN2150 Bad Disk Detected Refurbished
I recently bought this RND2150 refurbished. It came diskless. I did purchase a hard drive that was recommend and comptible using the Netgear website. However I am trying to install the unit on to my ...
May 11, 2019Guru - Experienced User
EmilyRogers22 wrote:
While all other lights are blinking green, with two slow blinks followed by three quick blinks. I am just trying to set up my unit. Is there a way to restart the install procress? To see if maybe I just goofed?
FWIW, the code you are reporting is actually "No disks detected".
LED blink behavior for 2 disk systems is three quick blinks of all disk LEDs and the backup LED, followed by an 1s delay, followed by a number of slow blinks. The number of slow blinks will be the error code.
Current error codes:
1 - Vendor mismatch
2 - No disks detected
3 - Bad contents on root partition of disks
4 - Flash error
5 - Unsupported RAID configuration
What disk drive did you purchase?
Try powering down the NAS, remove the drive, and power up again. Let us know if RAIDar detects the NAS.
