ShmulikTal's avatar
ShmulikTal
RBS850 not detected by router
My network includes one RBR850 + one RBS850 which came in one package, I later added another RBS850.
The new satellite was added successfully to the network.
The router and satellites are connected with ethernet cables.
Lately I saw that the new RBS850 is always displayed as offline in the ORBI app.
1. I tried to reconnect the newer RBS850 by pressing the synch button - still showed as offline
2. Tried factory reset the newer RBS850 and add it to the network - the wizard failed to detect the newer satellite, although, the blue light lit at the end of the pairing process, but the satellite is still displayed as offline.
3. Connected the newer satellite with a cable to a PC and confirmed that the firmware on the newer satellite is the same as the RBR and the second satellite  - all have the latest version V7.2.6.31.
Any suggestions before resetting the router and configuring the network again?
  • FURRYe38's avatar
    Does this show as offline on the RBRs web page as well? Or just in the Orbi app?
    What CAT# LAN cables are used to connect the RBS to the RBR? CAT6 is recommended.
    What is the distance between the router 📡 and satellite(s)🛰️? 30 feet or more is recommended in between RBR 📡 and RBS 🛰️ to begin with depending upon building materials when wired or wirelessly connected.
    https://kb.netgear.com/31029/Where-should-I-place-my-Orbi-satellite ‌‌🛰
    Be sure to disable any MAC Address randomizers on phones and pads while at home:
    https://community.netgear.com/t5/Orbi-App/NETGEAR-Mobile-Applications-and-Apple-Devices-FAQ/td-p/2220016/jump-to/first-unread-message
    • ShmulikTal's avatar
      ShmulikTal
      Thanks,
      I'm unable to access the RBR850 from the webpage, Browsing to orbilogin.net or 192.168.1.1 fails to connect, so my only access is via the app. The ip address for the router in the app is 10.0.0.1.
      My house is routed with CAT6 cables and the RBS is connected to the switch with CAT6.
      My house size is 350 sqr meters (about 3500 sqr feet) and I have 3 floors, the router is connected on the ground floor, with one RBS installed in the basement and on on the second floor.
      • FURRYe38's avatar
        Can you access the RBRs web page at 10.0.0.1?
