MacSI
Jun 19, 2017Aspirant
RN312 disk compatibility
Hello I want to upgrade storage in my RN312. Witch hard drive can I use ? Can I use WD60EFRX ? Thx
mdgm-ntgr
Jun 19, 2017NETGEAR Employee Retired
Yes you can use that model. There are many options on the hard disk compatibility list.
- ctechsJun 20, 2017Apprentice
The hard disk compatibility list is not showing up here. There's just a blank spot on the page where it should appear. Tested in both Firefox and Chrome. Edge has this message:
This content can’t be shown in a frameThere is supposed to be some content here, but the publisher doesn’t allow it to be displayed in a frame. This is to help protect the security of any information you might enter into this site.
- StephenBJun 20, 2017Guru - Experienced User
Yes. Netgear says they are working on it.
Use https://www.readynas.com/app/hcl_disk for now.
