MacSI
Jun 19, 2017Aspirant
RN312 disk compatibility
Hello I want to upgrade storage in my RN312. Witch hard drive can I use ? Can I use WD60EFRX ? Thx
mdgm-ntgr
Jun 19, 2017NETGEAR Employee Retired
Yes you can use that model. There are many options on the hard disk compatibility list.
ctechs
Jun 20, 2017Apprentice
The hard disk compatibility list is not showing up here. There's just a blank spot on the page where it should appear. Tested in both Firefox and Chrome. Edge has this message:
This content can’t be shown in a frame
There is supposed to be some content here, but the publisher doesn’t allow it to be displayed in a frame. This is to help protect the security of any information you might enter into this site.
- StephenBJun 20, 2017Guru - Experienced User
Yes. Netgear says they are working on it.
Use https://www.readynas.com/app/hcl_disk for now.
