pjhunter
May 10, 2020Aspirant
RN312 migration
I have a RN312 purchased in 2015. It is configured with 2 4TB WD Reds in a RAID 1 configuration. I understand that the 312 is at end of life, but I am having trouble finding a recommended upgrade p...
- May 11, 2020
It would be best if you will upgrade to a larger NAS like the RN424. This way, you will have more room for expansion if you are planning it.
You can use the RN312 still as backup but again as everyone is saying, a NAS is not purposed to be used as a back up device or the sole backup device. It is always best practice to make copies of your data.
Also, the RN424 has much better performance than the RN312.
HTH
Marc_V
May 11, 2020NETGEAR Employee Retired
HTH
- SandsharkMay 11, 2020Sensei
Marc_V wrote:You can use the RN312 still as backup but again as everyone is saying, a NAS is not purposed to be used as a back up device or the sole backup device. It is always best practice to make copies of your data.
A second NAS backing up a primary one, as he is suggesting, is an excellent backup device and is exactly one of it's best uses. Not as good if at the same site, but still good. Relying on a single NAS, either via RAID or a separate internal volume is not a reliable backup, since everything can be damaged by the same hardware failure.
