pjhunter's avatar
pjhunter
RN312 migration
I have a RN312 purchased in 2015.  It is configured with 2 4TB WD Reds in a RAID 1 configuration.  I understand that the 312 is at end of life, but I am having trouble finding a recommended upgrade p...
  • Marc_V's avatar
    May 11, 2020
    pjhunter
    It would be best if you will upgrade to a larger NAS like the RN424. This way, you will have more room for expansion if you are planning it.
    You can use the RN312 still as backup but again as everyone is saying, a NAS is not purposed to be used as a back up device or the sole backup device. It is always best practice to make copies of your data.
    Also, the RN424 has much better performance than the RN312.
    HTH
ProSupport for Business
