Retired_Member's avatar
Retired_Member
Mar 24, 2021
RN312 with 2xRJ45 switch ? +vlan setting deletion
Hi,
my question (#1) is how works RN312 with two ethernet ports. I have insufficient number of ports on my router/switch.
ReadyNAS unit is connected to router/switch using port 1, while port 2 is currently unused.
Is it possible to connect printer or ups backup unit to port 2 and accessing it for whole network?
Does it work like this by default, so i mean does ReadyNAS unit behave like switch for these two ports?
Or do i need to add some additional settings like VLAN or so? Please let me know how to make this.
Other thing (#2) is that i have tried creating VLAN, for both ports, while 1 is used and 2 unused and
i am unable to delete VLAN for currently unused port 2 which is grayed out (port 2 and vlan for port).
The error message i got is the following: Removal of VLAN setting failed. Error 40040200001.
Is it possible to delete the vlan using SSH or so? I know basic linux commands and I can edit files,
but honestly I dont know what file(s) to delete or edit for achieving VLAN for unused port 2 deletion.
Thank you
  • StephenB's avatar
    No, it doesn't behave like a switch.
    I think the best path is just to purchase an suitable switch - small unmanaged gigabit switches are really inexpensive.
    • Retired_Member's avatar
      Retired_Member
      So it would not be generally possible, to connect another device on LAN port 2 and create bridge mode somehow? I guess VLAN does not work like this (like bridge for 2 networks with same IP range)? But there is in IP address setting listing DHCP, so where from does it lease the DHCP address?
      I am still experiencing problem with the VLAN deletion on unactive LAN port 2, where is currently no device connected (attached screenshot).
      I have tried searching for "vlan" file, which results by list attached below, but i havent found any config file or so. Where is VLAN settings stored? I mean file name or file location. Please dont tell me i have to reinstall whole ReadyNAS OS for the one simple task. Thank you.
      Screenshot URL: https://abload.de/img/clipboard03abkbw.jpg
      root@NAS:/# find . -name vlan
      ./proc/1/task/1/net/vlan
      ./proc/1/net/vlan
      ./proc/2/task/2/net/vlan
      ./proc/2/net/vlan
      ./proc/3/task/3/net/vlan
      ./proc/3/net/vlan
      ./proc/5/task/5/net/vlan
      ./proc/5/net/vlan
      ./proc/7/task/7/net/vlan
      ./proc/7/net/vlan
      ./proc/8/task/8/net/vlan
      ./proc/8/net/vlan
      ./proc/9/task/9/net/vlan
      ./proc/9/net/vlan
      ./proc/10/task/10/net/vlan
      ./proc/10/net/vlan
      ./proc/11/task/11/net/vlan
      ./proc/11/net/vlan
      ./proc/12/task/12/net/vlan
      ./proc/12/net/vlan
      ./proc/13/task/13/net/vlan
      ./proc/13/net/vlan
      ./proc/15/task/15/net/vlan
      ./proc/15/net/vlan
      ./proc/16/task/16/net/vlan
      ./proc/16/net/vlan
      ./proc/17/task/17/net/vlan
      ./proc/17/net/vlan
      ./proc/18/task/18/net/vlan
      ./proc/18/net/vlan
      ./proc/20/task/20/net/vlan
      ./proc/20/net/vlan
      ./proc/21/task/21/net/vlan
      ./proc/21/net/vlan
      ./proc/22/task/22/net/vlan
      ./proc/22/net/vlan
      ./proc/23/task/23/net/vlan
      ./proc/23/net/vlan
      ./proc/25/task/25/net/vlan
      ./proc/25/net/vlan
      ./proc/26/task/26/net/vlan
      ./proc/26/net/vlan
      ./proc/27/task/27/net/vlan
      ./proc/27/net/vlan
      ./proc/30/task/30/net/vlan
      ./proc/30/net/vlan
      ./proc/391/task/391/net/vlan
      ./proc/391/net/vlan
      ./proc/392/task/392/net/vlan
      ./proc/392/net/vlan
      ./proc/394/task/394/net/vlan
      ./proc/394/net/vlan
      ./proc/395/task/395/net/vlan
      ./proc/395/net/vlan
      ./proc/397/task/397/net/vlan
      ./proc/397/net/vlan
      ./proc/533/task/533/net/vlan
      ./proc/533/net/vlan
      ./proc/636/task/636/net/vlan
      ./proc/636/net/vlan
      ./proc/664/task/664/net/vlan
      ./proc/664/net/vlan
      ./proc/665/task/665/net/vlan
      ./proc/665/net/vlan
      ./proc/741/task/741/net/vlan
      ./proc/741/net/vlan
      ./proc/754/task/754/net/vlan
      ./proc/754/net/vlan
      ./proc/760/task/760/net/vlan
      ./proc/760/net/vlan
      ./proc/796/task/796/net/vlan
      ./proc/796/net/vlan
      ./proc/816/task/816/net/vlan
      ./proc/816/net/vlan
      ./proc/835/task/835/net/vlan
      ./proc/835/net/vlan
      ./proc/838/task/838/net/vlan
      ./proc/838/net/vlan
      ./proc/841/task/841/net/vlan
      ./proc/841/net/vlan
      ./proc/844/task/844/net/vlan
      ./proc/844/net/vlan
      ./proc/847/task/847/net/vlan
      ./proc/847/net/vlan
      ./proc/850/task/850/net/vlan
      ./proc/850/net/vlan
      ./proc/853/task/853/net/vlan
      ./proc/853/net/vlan
      ./proc/856/task/856/net/vlan
      ./proc/856/net/vlan
      ./proc/881/task/881/net/vlan
      ./proc/881/net/vlan
      ./proc/904/task/904/net/vlan
      ./proc/904/net/vlan
      ./proc/906/task/906/net/vlan
      ./proc/906/net/vlan
      ./proc/909/task/909/net/vlan
      ./proc/909/net/vlan
      ./proc/910/task/910/net/vlan
      ./proc/910/net/vlan
      ./proc/913/task/913/net/vlan
      ./proc/913/net/vlan
      ./proc/914/task/914/net/vlan
      ./proc/914/net/vlan
      ./proc/916/task/916/net/vlan
      ./proc/916/net/vlan
      ./proc/918/task/918/net/vlan
      ./proc/918/net/vlan
      ./proc/921/task/921/net/vlan
      ./proc/921/net/vlan
      ./proc/922/task/922/net/vlan
      ./proc/922/net/vlan
      ./proc/925/task/925/net/vlan
      ./proc/925/net/vlan
      ./proc/926/task/926/net/vlan
      ./proc/926/net/vlan
      ./proc/930/task/930/net/vlan
      ./proc/930/net/vlan
      ./proc/931/task/931/net/vlan
      ./proc/931/net/vlan
      ./proc/932/task/932/net/vlan
      ./proc/932/net/vlan
      ./proc/933/task/933/net/vlan
      ./proc/933/net/vlan
      ./proc/934/task/934/net/vlan
      ./proc/934/net/vlan
      ./proc/954/task/954/net/vlan
      ./proc/954/net/vlan
      ./proc/956/task/956/net/vlan
      ./proc/956/net/vlan
      ./proc/958/task/958/net/vlan
      ./proc/958/net/vlan
      ./proc/959/task/959/net/vlan
      ./proc/959/net/vlan
      ./proc/1008/task/1008/net/vlan
      ./proc/1008/net/vlan
      ./proc/1012/task/1012/net/vlan
      ./proc/1012/net/vlan
      ./proc/1024/task/1024/net/vlan
      ./proc/1024/net/vlan
      ./proc/1049/task/1049/net/vlan
      ./proc/1049/net/vlan
      ./proc/1068/task/1068/net/vlan
      ./proc/1068/net/vlan
      ./proc/1075/task/1075/net/vlan
      ./proc/1075/net/vlan
      ./proc/1077/task/1077/net/vlan
      ./proc/1077/net/vlan
      ./proc/1173/task/1173/net/vlan
      ./proc/1173/net/vlan
      ./proc/1189/task/1189/net/vlan
      ./proc/1189/net/vlan
      ./proc/1192/task/1192/net/vlan
      ./proc/1192/net/vlan
      ./proc/1196/task/1196/net/vlan
      ./proc/1196/net/vlan
      ./proc/1197/task/1197/net/vlan
      ./proc/1197/net/vlan
      ./proc/1198/task/1198/net/vlan
      ./proc/1198/net/vlan
      ./proc/1202/task/1202/net/vlan
      ./proc/1202/net/vlan
      ./proc/1206/task/1206/net/vlan
      ./proc/1206/net/vlan
      ./proc/1207/task/1207/net/vlan
      ./proc/1207/net/vlan
      ./proc/1208/task/1208/net/vlan
      ./proc/1208/net/vlan
      ./proc/1212/task/1212/net/vlan
      ./proc/1212/net/vlan
      ./proc/1214/task/1214/net/vlan
      ./proc/1214/net/vlan
      ./proc/1215/task/1215/net/vlan
      ./proc/1215/net/vlan
      ./proc/1216/task/1216/net/vlan
      ./proc/1216/net/vlan
      ./proc/1217/task/1217/net/vlan
      ./proc/1217/net/vlan
      ./proc/1218/task/1218/net/vlan
      ./proc/1218/net/vlan
      ./proc/1219/task/1219/net/vlan
      ./proc/1219/net/vlan
      ./proc/1220/task/1220/net/vlan
      ./proc/1220/net/vlan
      ./proc/1221/task/1221/net/vlan
      ./proc/1221/net/vlan
      ./proc/1222/task/1222/net/vlan
      ./proc/1222/net/vlan
      ./proc/1223/task/1223/net/vlan
      ./proc/1223/net/vlan
      ./proc/1224/task/1224/net/vlan
      ./proc/1224/net/vlan
      ./proc/1225/task/1225/net/vlan
      ./proc/1225/net/vlan
      ./proc/1226/task/1226/net/vlan
      ./proc/1226/net/vlan
      ./proc/1227/task/1227/net/vlan
      ./proc/1227/net/vlan
      ./proc/1228/task/1228/net/vlan
      ./proc/1228/net/vlan
      ./proc/1229/task/1229/net/vlan
      ./proc/1229/net/vlan
      ./proc/1230/task/1230/net/vlan
      ./proc/1230/net/vlan
      ./proc/1231/task/1231/net/vlan
      ./proc/1231/net/vlan
      ./proc/1232/task/1232/net/vlan
      ./proc/1232/net/vlan
      ./proc/1233/task/1233/net/vlan
      ./proc/1233/net/vlan
      ./proc/1245/task/1245/net/vlan
      ./proc/1245/net/vlan
      ./proc/1248/task/1248/net/vlan
      ./proc/1248/net/vlan
      ./proc/1271/task/1271/net/vlan
      ./proc/1271/net/vlan
      ./proc/1273/task/1273/net/vlan
      ./proc/1273/net/vlan
      ./proc/1294/task/1294/net/vlan
      ./proc/1294/net/vlan
      ./proc/1309/task/1309/net/vlan
      ./proc/1309/net/vlan
      ./proc/1319/task/1319/net/vlan
      ./proc/1319/net/vlan
      ./proc/1320/task/1320/net/vlan
      ./proc/1320/net/vlan
      ./proc/1321/task/1321/net/vlan
      ./proc/1321/net/vlan
      ./proc/1340/task/1340/net/vlan
      ./proc/1340/net/vlan
      ./proc/1341/task/1341/net/vlan
      ./proc/1341/net/vlan
      ./proc/1342/task/1342/net/vlan
      ./proc/1342/net/vlan
      ./proc/1343/task/1343/net/vlan
      ./proc/1343/net/vlan
      ./proc/1344/task/1344/net/vlan
      ./proc/1344/net/vlan
      ./proc/1345/task/1345/net/vlan
      ./proc/1345/net/vlan
      ./proc/1346/task/1346/net/vlan
      ./proc/1346/net/vlan
      ./proc/1347/task/1347/net/vlan
      ./proc/1347/net/vlan
      ./proc/1348/task/1348/net/vlan
      ./proc/1348/net/vlan
      ./proc/1349/task/1349/net/vlan
      ./proc/1349/net/vlan
      ./proc/1350/task/1350/net/vlan
      ./proc/1350/net/vlan
      ./proc/1351/task/1351/net/vlan
      ./proc/1351/net/vlan
      ./proc/1352/task/1352/net/vlan
      ./proc/1352/net/vlan
      ./proc/1354/task/1354/net/vlan
      ./proc/1354/net/vlan
      ./proc/1355/task/1355/net/vlan
      ./proc/1355/net/vlan
      ./proc/1356/task/1356/net/vlan
      ./proc/1356/net/vlan
      ./proc/1357/task/1357/net/vlan
      ./proc/1357/net/vlan
      ./proc/1358/task/1358/net/vlan
      ./proc/1358/net/vlan
      ./proc/1359/task/1359/net/vlan
      ./proc/1359/net/vlan
      ./proc/2557/task/2557/net/vlan
      ./proc/2557/net/vlan
      ./proc/2558/task/2558/net/vlan
      ./proc/2558/net/vlan
      ./proc/2574/task/2574/net/vlan
      ./proc/2574/net/vlan
      ./proc/2575/task/2575/net/vlan
      ./proc/2575/task/2583/net/vlan
      ./proc/2575/net/vlan
      ./proc/2576/task/2576/net/vlan
      ./proc/2576/net/vlan
      ./proc/2578/task/2578/net/vlan
      ./proc/2578/net/vlan
      ./proc/2579/task/2579/net/vlan
      ./proc/2579/net/vlan
      ./proc/2584/task/2584/net/vlan
      ./proc/2584/net/vlan
      ./proc/2587/task/2587/net/vlan
      ./proc/2587/net/vlan
      ./proc/2588/task/2588/net/vlan
      ./proc/2588/task/2698/net/vlan
      ./proc/2588/net/vlan
      ./proc/2590/task/2590/net/vlan
      ./proc/2590/net/vlan
      ./proc/2591/task/2591/net/vlan
      ./proc/2591/net/vlan
      ./proc/2592/task/2592/net/vlan
      ./proc/2592/net/vlan
      ./proc/2623/task/2623/net/vlan
      ./proc/2623/net/vlan
      ./proc/2626/task/2626/net/vlan
      ./proc/2626/net/vlan
      ./proc/2629/task/2629/net/vlan
      ./proc/2629/net/vlan
      ./proc/2630/task/2630/net/vlan
      ./proc/2630/net/vlan
      ./proc/2634/task/2634/net/vlan
      ./proc/2634/net/vlan
      ./proc/2734/task/2734/net/vlan
      ./proc/2734/net/vlan
      ./proc/2805/task/2805/net/vlan
      ./proc/2805/net/vlan
      ./proc/2830/task/2830/net/vlan
      ./proc/2830/net/vlan
      ./proc/2835/task/2835/net/vlan
      ./proc/2835/task/2851/net/vlan
      ./proc/2835/task/2876/net/vlan
      ./proc/2835/task/2878/net/vlan
      ./proc/2835/task/2879/net/vlan
      ./proc/2835/task/2880/net/vlan
      ./proc/2835/task/2883/net/vlan
      ./proc/2835/task/2887/net/vlan
      ./proc/2835/task/2888/net/vlan
      ./proc/2835/task/2917/net/vlan
      ./proc/2835/task/2918/net/vlan
      ./proc/2835/task/2919/net/vlan
      ./proc/2835/task/2920/net/vlan
      ./proc/2835/task/2921/net/vlan
      ./proc/2835/task/2985/net/vlan
      ./proc/2835/task/3013/net/vlan
      ./proc/2835/task/3030/net/vlan
      ./proc/2835/task/3065/net/vlan
      ./proc/2835/task/3066/net/vlan
      ./proc/2835/task/3067/net/vlan
      ./proc/2835/task/3509/net/vlan
      ./proc/2835/task/3514/net/vlan
      ./proc/2835/task/3517/net/vlan
      ./proc/2835/task/3538/net/vlan
      ./proc/2835/task/3564/net/vlan
      ./proc/2835/task/3577/net/vlan
      ./proc/2835/task/3590/net/vlan
      ./proc/2835/task/3613/net/vlan
      ./proc/2835/task/3627/net/vlan
      ./proc/2835/task/3628/net/vlan
      ./proc/2835/task/3629/net/vlan
      ./proc/2835/task/3630/net/vlan
      ./proc/2835/task/3631/net/vlan
      ./proc/2835/task/3632/net/vlan
      ./proc/2835/task/3640/net/vlan
      ./proc/2835/task/3643/net/vlan
      ./proc/2835/task/3645/net/vlan
      ./proc/2835/task/3647/net/vlan
      ./proc/2835/task/3649/net/vlan
      ./proc/2835/task/3651/net/vlan
      ./proc/2835/task/3653/net/vlan
      ./proc/2835/task/3655/net/vlan
      ./proc/2835/task/3663/net/vlan
      ./proc/2835/task/3664/net/vlan
      ./proc/2835/task/3665/net/vlan
      ./proc/2835/task/4086/net/vlan
      ./proc/2835/task/4087/net/vlan
      ./proc/2835/task/4096/net/vlan
      ./proc/2835/task/4099/net/vlan
      ./proc/2835/task/4100/net/vlan
      ./proc/2835/task/4101/net/vlan
      ./proc/2835/task/4104/net/vlan
      ./proc/2835/task/4106/net/vlan
      ./proc/2835/task/4107/net/vlan
      ./proc/2835/task/4108/net/vlan
      ./proc/2835/task/4109/net/vlan
      ./proc/2835/task/4113/net/vlan
      ./proc/2835/task/4114/net/vlan
      ./proc/2835/task/4116/net/vlan
      ./proc/2835/task/4118/net/vlan
      ./proc/2835/task/4119/net/vlan
      ./proc/2835/task/4120/net/vlan
      ./proc/2835/task/4121/net/vlan
      ./proc/2835/task/4122/net/vlan
      ./proc/2835/task/4124/net/vlan
      ./proc/2835/task/4131/net/vlan
      ./proc/2835/task/4132/net/vlan
      ./proc/2835/task/4133/net/vlan
      ./proc/2835/task/4134/net/vlan
      ./proc/2835/task/4135/net/vlan
      ./proc/2835/task/4136/net/vlan
      ./proc/2835/task/4137/net/vlan
      ./proc/2835/task/4345/net/vlan
      ./proc/2835/task/4354/net/vlan
      ./proc/2835/task/4395/net/vlan
      ./proc/2835/task/4396/net/vlan
      ./proc/2835/task/4397/net/vlan
      ./proc/2835/task/5146/net/vlan
      ./proc/2835/task/7984/net/vlan
      ./proc/2835/task/7985/net/vlan
      ./proc/2835/task/7987/net/vlan
      ./proc/2835/task/7988/net/vlan
      ./proc/2835/net/vlan
      ./proc/2843/task/2843/net/vlan
      ./proc/2843/task/2856/net/vlan
      ./proc/2843/task/2866/net/vlan
      ./proc/2843/task/2867/net/vlan
      ./proc/2843/task/2868/net/vlan
      ./proc/2843/task/2884/net/vlan
      ./proc/2843/task/2885/net/vlan
      ./proc/2843/task/2886/net/vlan
      ./proc/2843/task/2890/net/vlan
      ./proc/2843/task/2891/net/vlan
      ./proc/2843/task/2892/net/vlan
      ./proc/2843/task/2893/net/vlan
      ./proc/2843/task/2894/net/vlan
      ./proc/2843/task/2895/net/vlan
      ./proc/2843/task/2896/net/vlan
      ./proc/2843/task/2897/net/vlan
      ./proc/2843/task/2898/net/vlan
      ./proc/2843/task/2899/net/vlan
      ./proc/2843/task/2900/net/vlan
      ./proc/2843/task/2901/net/vlan
      ./proc/2843/task/2902/net/vlan
      ./proc/2843/task/2903/net/vlan
      ./proc/2843/task/2904/net/vlan
      ./proc/2843/task/2905/net/vlan
      ./proc/2843/task/2906/net/vlan
      ./proc/2843/net/vlan
      ./proc/2853/task/2853/net/vlan
      ./proc/2853/net/vlan
      ./proc/2854/task/2854/net/vlan
      ./proc/2854/net/vlan
      ./proc/2864/task/2864/net/vlan
      ./proc/2864/task/2928/net/vlan
      ./proc/2864/task/2937/net/vlan
      ./proc/2864/task/3103/net/vlan
      ./proc/2864/task/3104/net/vlan
      ./proc/2864/task/3105/net/vlan
      ./proc/2864/task/3106/net/vlan
      ./proc/2864/task/3107/net/vlan
      ./proc/2864/task/3353/net/vlan
      ./proc/2864/task/3366/net/vlan
      ./proc/2864/task/3369/net/vlan
      ./proc/2864/task/3411/net/vlan
      ./proc/2864/task/3412/net/vlan
      ./proc/2864/task/3413/net/vlan
      ./proc/2864/task/3491/net/vlan
      ./proc/2864/net/vlan
      ./proc/3439/task/3439/net/vlan
      ./proc/3439/net/vlan
      ./proc/3447/task/3447/net/vlan
      ./proc/3447/net/vlan
      ./proc/3449/task/3449/net/vlan
      ./proc/3449/net/vlan
      ./proc/3450/task/3450/net/vlan
      ./proc/3450/net/vlan
      ./proc/3493/task/3493/net/vlan
      ./proc/3493/task/3500/net/vlan
      ./proc/3493/task/3501/net/vlan
      ./proc/3493/net/vlan
      ./proc/3516/task/3516/net/vlan
      ./proc/3516/task/3519/net/vlan
      ./proc/3516/task/3520/net/vlan
      ./proc/3516/task/3521/net/vlan
      ./proc/3516/task/3530/net/vlan
      ./proc/3516/task/3532/net/vlan
      ./proc/3516/task/3617/net/vlan
      ./proc/3516/task/3618/net/vlan
      ./proc/3516/task/3619/net/vlan
      ./proc/3516/task/3620/net/vlan
      ./proc/3516/task/3633/net/vlan
      ./proc/3516/task/3634/net/vlan
      ./proc/3516/task/3635/net/vlan
      ./proc/3516/task/3636/net/vlan
      ./proc/3516/task/3637/net/vlan
      ./proc/3516/task/3638/net/vlan
      ./proc/3516/task/3639/net/vlan
      ./proc/3516/task/3641/net/vlan
      ./proc/3516/task/3642/net/vlan
      ./proc/3516/task/3644/net/vlan
      ./proc/3516/task/3646/net/vlan
      ./proc/3516/task/3648/net/vlan
      ./proc/3516/task/3650/net/vlan
      ./proc/3516/task/3652/net/vlan
      ./proc/3516/task/3654/net/vlan
      ./proc/3516/task/3656/net/vlan
      ./proc/3516/task/4089/net/vlan
      ./proc/3516/task/4102/net/vlan
      ./proc/3516/task/4103/net/vlan
      ./proc/3516/task/4105/net/vlan
      ./proc/3516/task/4164/net/vlan
      ./proc/3516/task/4307/net/vlan
      ./proc/3516/task/4308/net/vlan
      ./proc/3516/task/4309/net/vlan
      ./proc/3516/task/4310/net/vlan
      ./proc/3516/task/4311/net/vlan
      ./proc/3516/task/4312/net/vlan
      ./proc/3516/task/4313/net/vlan
      ./proc/3516/task/4314/net/vlan
      ./proc/3516/task/4315/net/vlan
      ./proc/3516/task/4316/net/vlan
      ./proc/3516/task/4317/net/vlan
      ./proc/3516/task/4318/net/vlan
      ./proc/3516/task/4319/net/vlan
      ./proc/3516/task/4320/net/vlan
      ./proc/3516/task/4321/net/vlan
      ./proc/3516/task/4322/net/vlan
      ./proc/3516/task/4323/net/vlan
      ./proc/3516/task/4324/net/vlan
      ./proc/3516/task/4325/net/vlan
      ./proc/3516/task/4326/net/vlan
      ./proc/3516/task/4327/net/vlan
      ./proc/3516/task/4328/net/vlan
      ./proc/3516/task/4329/net/vlan
      ./proc/3516/task/4330/net/vlan
      ./proc/3516/task/4331/net/vlan
      ./proc/3516/task/4371/net/vlan
      ./proc/3516/task/4372/net/vlan
      ./proc/3516/task/4373/net/vlan
      ./proc/3516/task/4374/net/vlan
      ./proc/3516/task/4375/net/vlan
      ./proc/3516/task/4376/net/vlan
      ./proc/3516/task/4377/net/vlan
      ./proc/3516/task/4378/net/vlan
      ./proc/3516/task/4379/net/vlan
      ./proc/3516/task/4405/net/vlan
      ./proc/3516/task/4406/net/vlan
      ./proc/3516/task/4407/net/vlan
      ./proc/3516/task/4449/net/vlan
      ./proc/3516/task/7989/net/vlan
      ./proc/3516/task/7990/net/vlan
      ./proc/3516/task/7993/net/vlan
      ./proc/3516/task/7994/net/vlan
      ./proc/3516/task/7995/net/vlan
      ./proc/3516/task/7996/net/vlan
      ./proc/3516/net/vlan
      ./proc/3526/task/3526/net/vlan
      ./proc/3526/net/vlan
      ./proc/3557/task/3557/net/vlan
      ./proc/3557/net/vlan
      ./proc/3704/task/3704/net/vlan
      ./proc/3704/net/vlan
      ./proc/4183/task/4183/net/vlan
      ./proc/4183/net/vlan
      ./proc/4370/task/4370/net/vlan
      ./proc/4370/net/vlan
      ./proc/4456/task/4456/net/vlan
      ./proc/4456/net/vlan
      ./proc/4593/task/4593/net/vlan
      ./proc/4593/net/vlan
      ./proc/4627/task/4627/net/vlan
      ./proc/4627/net/vlan
      ./proc/5411/task/5411/net/vlan
      ./proc/5411/net/vlan
      ./proc/5712/task/5712/net/vlan
      ./proc/5712/net/vlan
      ./proc/5768/task/5768/net/vlan
      ./proc/5768/net/vlan
      ./proc/6606/task/6606/net/vlan
      ./proc/6606/net/vlan
      ./proc/6980/task/6980/net/vlan
      ./proc/6980/net/vlan
      ./proc/7211/task/7211/net/vlan
      ./proc/7211/net/vlan
      ./proc/7228/task/7228/net/vlan
      ./proc/7228/net/vlan
      ./proc/7351/task/7351/net/vlan
      ./proc/7351/net/vlan
      ./proc/7418/task/7418/net/vlan
      ./proc/7418/net/vlan
      ./proc/7554/task/7554/net/vlan
      ./proc/7554/net/vlan
      ./proc/7601/task/7601/net/vlan
      ./proc/7601/net/vlan
      ./proc/7673/task/7673/net/vlan
      ./proc/7673/net/vlan
      ./proc/7705/task/7705/net/vlan
      ./proc/7705/net/vlan
      ./proc/7762/task/7762/net/vlan
      ./proc/7762/net/vlan
      ./proc/8006/task/8006/net/vlan
      ./proc/8006/net/vlan
      ./proc/8007/task/8007/net/vlan
      ./proc/8007/net/vlan
      ./proc/8059/task/8059/net/vlan
      ./proc/8059/net/vlan
      ./proc/8080/task/8080/net/vlan
      ./proc/8080/net/vlan
      ./proc/8083/task/8083/net/vlan
      ./proc/8083/net/vlan
      ./proc/8355/task/8355/net/vlan
      ./proc/8355/task/8359/net/vlan
      ./proc/8355/task/8360/net/vlan
      ./proc/8355/task/8361/net/vlan
      ./proc/8355/task/8362/net/vlan
      ./proc/8355/task/8363/net/vlan
      ./proc/8355/task/8364/net/vlan
      ./proc/8355/net/vlan
      ./proc/8357/task/8357/net/vlan
      ./proc/8357/net/vlan
      ./proc/8457/task/8457/net/vlan
      ./proc/8457/net/vlan
      ./proc/8573/task/8573/net/vlan
      ./proc/8573/task/8584/net/vlan
      ./proc/8573/task/8585/net/vlan
      ./proc/8573/task/8586/net/vlan
      ./proc/8573/task/8587/net/vlan
      ./proc/8573/net/vlan
      ./proc/8588/task/8588/net/vlan
      ./proc/8588/net/vlan
      ./proc/8606/task/8606/net/vlan
      ./proc/8606/net/vlan
      ./proc/8734/task/8734/net/vlan
      ./proc/8734/net/vlan
      ./proc/8747/task/8747/net/vlan
      ./proc/8747/net/vlan
        Retired_Member
        Ok, so i have found file /etc/network/interfaces where was located vlan configuration. I have truncated the file to 0 bytes and voila, it works.
        So now, it only remains the first part of my question to answer.
        So it would not be generally possible, to connect another device on LAN port 2 and create bridge mode somehow? I guess VLAN does not work like this (like bridge for 2 networks with same IP range)? But there is in IP address setting listing DHCP option, so where from does it lease the DHCP address? If i would connect some device to the the LAN port 2, would it lease IP address from home network router, which is connected to my NAS server through LAN port 1?
        Thank you in advance for your help.
ProSupport for Business
