julesg1
Jul 06, 2015Tutor
RN314 4 TB external HDD showing up as 1.8 TB
Hello, I have a Seagate ST4000DM000 HDD that is on the compatibility list. I tried connecting this drive via USB and eSATA but on both cases, the drive is showing up as only 1.8 TB (actually I think i...
RX
Jul 06, 2015Luminary
Is the Seagate ST4000DM000 HDD new?
If you connect the Seagate ST4000DM000 HDD directly to a PC, is it detect approx. 4TB of capacity?
Try to run a disk check on it using Seagate SeaTools and run an Extended test on it. Check this link: http://www.seagate.com/as/en/support/do ... in-master/
