ZkiiFreak
Jan 27, 2014Aspirant
RN314 front display (LED)
Hi Got the RN314. On the front display, the LED, a stikers says "press the power button once to..." and something is supposed to show in the display. Problem is, nothing shows when I press the power...
ZkiiFreak
Jan 28, 2014Aspirant
mdgm wrote: How long did you press the power button for? If only momentarily try pressing it a little longer.
I've tried what I think is every possible solution:
Momentarily press
Press one second
Press two seconds
Press harder / lighter for the above combinations.
If I press the button more than that, the NAS shuts down (expected behavior)
Maybe the "connection" just doesn't work on my unit? Anyway to tell (other than the obvious at hand and try it out)?
Thanks for the replies
/Martin
