claynz
Dec 15, 2019Guide
RN314 Log Message
Anything to worry about? 2019-12-12 09:44:58: BTRFS: error (device md126) in btrfs_commit_transaction:2241: errno=-5 IO failure (Error while writing out transaction)
Marc_V
Dec 15, 2019NETGEAR Employee Retired
BTRFS errors always needs attention. Do you have any failing drive warnings? You may want to send us through Google drive your full logs.
Options when having file system errors would be to contact Support and purchase a contract or Pay per Incident Support, another is to have full backup and do a Factory Reset and start fresh.
HTH
Regards
claynz
Dec 15, 2019Guide
The drives are new and all show as healthy, I didn't factory reset with paper clip when installing the new drives, but can do that as all my data has been backed up off the NAS
I had to create different volumes as appose to X-RAID
4x 10TB drives
Drive 1 = 10TB JBOD
Drive 2 = 10TB JBOD
Drive 3 & 4 = 20TB RAID0
Or should I send you the log files instead, takes me 2 days to backup all my data to the NAS
- StephenBDec 15, 2019Guru - Experienced User
claynz wrote:
4x 10TB drives
Drive 1 = 10TB JBOD
Drive 2 = 10TB JBOD
Instead of a reset, you can try deleting/recreating just the volume that is read-only, and leave the others alone.
- Oct 24, 2016Retired_Member
