marsmars
Jun 20, 2018Aspirant
RN314 mount_block_root+1f1 and cannot access the boot menu
Hi.
My system is RN314 with 4x6TB HDD and was working fine for more than a year now. The firmware was updated several times in the past with no issues.
Yesterday I updated my system to new fi...
- Jun 21, 2018
OK.
Managed to do it. The normal method did not work. And the problem was not in USB keys.
Using Rufus and selecting a boot selection of syslinux 6.03 (will only show if you select show advanced drive properties). set others as defaults.
Then using usb recovery tool just to prepare the disk and not format it.
The rest is as described in the link you provided
And thanks for your help.
mdgm-ntgr
Jun 20, 2018NETGEAR Employee Retired
Try USB Boot Recovery: How do I use the USB Recovery Tool on my ReadyNAS OS 6 storage system?
marsmars
Jun 21, 2018Aspirant
Thanks for the replay.
I am doing that.
- marsmarsJun 21, 2018Aspirant
OK.
I have tried 4 different USB keys (from 1GB to 32 GB) using latest frimware ReadyNASOS-6.9.3-x86_64 for RN314
Only 1GB key gives an indication that it booting from external USB. and remains there (40 minutes and counting).
The others gives the msg for may be 10 seconds then again gives the mount_block_root+1f1 msg.
What can I do next?
OK.
- mdgm-ntgrJun 21, 2018NETGEAR Employee Retired
Glad that it’s now resolved. Thanks for sharing what worked for you.
