alfb
Sep 30, 2022Aspirant
RN314 problems after Readynas 6.10.7
After install of 6.10.7 (apparently trouble free) on a RN314 (4*6TD WD drves) that has been in use for years, the gui degrades to the point where no data appears in the admin page. In the short time...
- Oct 02, 2022
alfb wrote:
So should I hot swap sdb (drive 2 as 1,2,3,4) or is it sbd (drive 2 as in 0,1,2,3) The output from mdstat infers drive numbers are 0,1,2,3
And are these numbers from left to right as looking from the front??
One caution is that the error in the screen shot is a read error - normally if mdadm is rebuilding a disk, it is writing to it. So there still is some uncertainty on exactly what is going on.
sdb is normally the second disk from the left (the disk in the first slot normally is sda).
If you aren't certain, you can also get the serial number with smartctl -x /dev/sdb (along with a lot of other information). Then you could power down the NAS, check the disk serial, and boot up the NAS read-only without it. If the volume is there, but degraded, then you could reboot again normally. Then do a hot-insert of the replacement.
Instructions on booting the NAS read-only are on pages 74-75 here:
Sep 30, 2022Guru - Experienced User
alfb wrote:
Can I replace the faulty drive with a new one, or must I wait for the resync to complete?
If the drive that is resyncing is the faulty one, then you don't need to wait.
But if it is a different drive, then you do.
alfb wrote:
If I can replace the drive, is the proper procedure to hot swap the drive, or should I shutdown, replace the drive and power up?
I generally recommend a hot swap. The system then detects the removal and reinsertion, and doesn't need to figure out that a drive was replaced.
alfb wrote:
Given the lack of normal behaviour of the admin gui, I am cautious about attempting to either:
- upgrade to 6.10.8
- downgrade to 6.10.6
- reinstall 6.10.7
The failing disk could be the cause of the poor performance. I wouldn't do any of these things at present.
- alfbOct 01, 2022Aspirant
StephenB,
Thanks for your advice.
Re
I am not sure which drive is resyncing. I will try to copy the output of /proc/mdstat to show you what I know. It shows md126 with the activity, but no indication that I can see of drive 1 or 2 or 3 or 4
Perhaps there is a different cli command?
Regards, Alf
- StephenBOct 01, 2022Guru - Experienced User
Try mdadm --detail /dev/md126
StephenB, thanks again for your interest.
Here is a screen shot of the command output. I'm still no wiser as to which physical drive is being resynced.
Regards, Alf
