david_spittle
Jun 23, 2022Tutor
RN314 scheduled snapshots not working on some shares
Hi I have had smart snapshots enabled for years on my 314. Recently the scheduled snapshots on my main Projects share stopped working. It seems that all of the old snapshots are gone (no harm done)...
david_spittle
Jun 24, 2022Tutor
Hi
I have 6.7TB data, 4.3TB snapshots, 5.19TB free. Raid 5.
Jun 25, 2022Guru - Experienced User
You could try disabling/re-enabling snapshots on the share, and see if that helps. There might also be some useful clues in the log zip file, so you could look there around the time(s) the snapshots are created.
Another possible path is to move the data into a new share that has snapshots enabled, and then delete the old one (renaming the new one to match the original name).
- david_spittleJun 26, 2022TutorThere doesn’t appear to be anything in the log when the hourly snapshot is meant to occur. It simply does nothing.
I’m running a VPN with security permissions on folders. Do you think there would be a way to dig deeper without having to break this?
Disabling and re-enabling didn’t do anything.- StephenBJun 27, 2022Guru - Experienced User
david_spittle wrote:
There doesn’t appear to be anything in the log when the hourly snapshot is meant to occur. It simply does nothing.Are you running "smart" snapshots or "custom"?
- david_spittleJun 27, 2022TutorHi
Using Smart snapshots.
